- Joined Jan 23, 2018
- 28,171
It looks to me like R1 from the output to the base of Q1 is providing some negative feedback.Most audio amplifiers have negative feedback from the output to reduce distortion. The original circuit does not.
Thanks. I will look at this!This circuit I designed will do that and has been verified on the breadboard.
Certainly a better design. Thanks.Thanks. I will look at this!
Hi:Thanks. I will look at this!
Can you convert that file to some other format?Here is a sim of your circuit.
I mentioned the original circuit that has R1 connected to VCC.It looks to me like R1 from the output to the base of Q1 is providing some negative feedback.
Probably. The 10ma refers to the total current with no input signal which is mostly the output transistors as mentioned previously.It looks like the current through R6 is only 961 uA.
The total current drain on the supProbably. The 10ma refers to the total current with no input signal which is mostly the output transistors as mentioned previously.
Have you tried using different values for R5 up to 1K in the simulator?
The current drain on the supply is only 1.5 mA (per simulation) with R5 at 500 ohms. The value of R5Probably. The 10ma refers to the total current with no input signal which is mostly the output transistors as mentioned previously.
Hi.If you build the circuit as designed R5 will definitely affect the current drain.
I found that 10ma was sufficient to remove any crossover distortion.
Thanks. I will delve into this circuit also.For your interest, below is the sim of a perhaps more elegant circuit, that uses a differential input stage (Q1 and Q2) with both AC and DC negative feedback from the output to bias the output at 1/2 the supply voltage largely independent of transistor or diode variations, establish the gain and reduce distortion (around 0.2% in the sim).
Since the 2N2222 is obsolete, what would be a good substitute?Thanks. I will delve into this circuit also.
2N2222A or 2N2222A-BSince the 2N2222 is obsolete, what would be a good substitute?
M
Can't get them.2N2222A or 2N2222A-B
Thanks.PN2222A
Thanks.Or P2N2222A or PN2222
Those are plastic package versions of the 2N2222(A).
In that circuit you could also substitute most small NPN's such as the 2N3904.
