Loudspeaker is exploding when connected to 555 astable mode.
Epathitis
Joined Jun 3, 2024
5
I am trying to build an audio circuit with an oscillator releasing a 3000Hz 9V square wave DC. I do not understand why the loudspeaker keeps on exploding in my simulations. I have put an electrolytic capacitor already to block any DC components from the damaging the loudspeaker but it keeps on exploding in the simulation. Am I missing something?
I am using Circuit Wizard 2.00
Here is my circuit:
Ian0
Joined Aug 7, 2020
13,275
It won't work, because your discharge path for C3 is via 10,100Ω (R7,R^) but I don't see how it can explode.
(Did a PP3 ever make anything explode?)
A NE555 can get adequate volume out of a speaker with a 100Ω series resistor. Or look for a 64Ω speaker.
Epathitis
Joined Jun 3, 2024
5
You need to describe exactly what you mean by the speaker "exploding" in the simulation.
Circuit Wizard has an Explosion Feature in simulations. It causes the components to explode once they are subjected beyond their limitations. It usually happens when there is something wrong with the circuit.
Epathitis
Joined Jun 3, 2024
5
What do you suggest I should do?
AnalogKid
Joined Aug 1, 2013
12,268
The circuit has issues, but that exploding thing is strictly a simulator artifact. Change the parameters / attributes / whatever for LS1 to make it a speaker rated for 20 W.
Here is just one of the circuit's issues:
C3 and the speaker's coil resistance form a highpass filter with a cutoff freq of 199 kHz. This is over six octaves above the 555 output freq of 3 kHz, for an attenuation of 36 dB. A bipolar 555 running on 9 V will make an output of approx. 7 V peak-to-peak. Even if the buffer amplifier increased the waveform to a full 9 Vpp (and it cannot), the speaker voltage would be only 140 mV.
The simulator has no problem with this, but the circuit will make a very low audible output IRL.
ak
panic mode
Joined Oct 10, 2011
5,241
you typed this directly after quote suggesting just that... two suggestions in fact:
a) A NE555 can get adequate volume out of a speaker with a 100Ω series resistor.
b) Or look for a 64Ω speaker.
and both of them are to ditch the transistors and drive speaker from 555
bertus
Joined Apr 5, 2008
23,005
The second picture shows the opened box with all values present.
You can also see that they are electrolitic capacitors.
Bertus
38,797
Does anyone know why you would use a small value (say below 1µF) electrolytic capacitor instead of a ceramic, which are non-polarized, more reliable, and generally have better characteristics?
panic mode
Joined Oct 10, 2011
5,241
and equally not documented.... no list of values or voltage rating. i would never buy something like that, to me that is a scam.
