Looking for IC that generates a delayed GND signal
abh123
Joined Jun 4, 2019
7
Hi
I have a project with a board that required a button to turn it ON “1 click to GND”
And i really don’t want add a physical button for the main board, because i already have a power button so
Im looking for ic when i turn the power on it generates “1 gnd single click” to turn the main board ON
Any idea will be appreciated!
35,322
A simple solution is a 555-timer circuit with a transistor output to sink current.
You need to provide more information in order for someone to suggest a solution.
How many seconds duration does the GND signal need to be?
How much current must the GND connection take?
It would be better if you gave us the whole picture.
What is the circuit that requires a GND signal?
abh123
Joined Jun 4, 2019
7
Sorry I didn't provide much information, Im not really sure what the ground current is but the time i think something between 200-500 millisecond should work
Its a sony playstation 2 it requires a button to turn it ON even if all regulators is turned on
abh123
Joined Jun 4, 2019
7
Does it turn on if both buttons are pressed at the same time or must there be a delay between power-on and system-on?
It needs to be delay after the regulator turns on,
Let me explain how ps2 and my power management are working.
- PS2 power button
1 press turn on
After it turned on 1 press to reset
Long press to turn off
In my project no need for reset and turn off.
- my power management button
1sec press to turn the regulators on & off
and 1 press to check the battery level
so if you mean to use the power button as power on for the both ps2&power management unfortunately it will not work.
Deleted member 115935
Joined Dec 31, 1969
What your looking at is connecting a signal to ground after / for a time,
rather different from delaying ground.
A nice little FET, with an RC circuit would be simple,
or use a power on reset chip,
abh123
Joined Jun 4, 2019
7
I'm a beginner in electronics, maybe there are some things not very clear to me and yes that what i looking for but i don’t want the signal stay in ground indefinitely otherwise it will turn the system off, i just want a one single ground click to push the system ON
38,952
Below is the LTspice simulation of a one-shot delay circuit using one CD4093 Schmidt-trigger quad NAND gate package:
It turns on MOSFET M1 to ground (blue trace) for ≈1s after about a 1.5s delay from the application of 5V power (green trace).
The output connection is the MOSFET drain (SW).
abh123
Joined Jun 4, 2019
7
Thanks man, i really appreciate your help!
