Looking for ic equivalent
David64
Joined Dec 25, 2019
Looking for a good equivalent to a mos fet smd IC AO4614 ideally from RS if anyone can help please.
Thanks David
pmd34
Joined Feb 22, 2014
529
Hi David,
The best thing for this is to actually go to Mouser (RS has always had a very bad Parametric search, but now Farnel have joined them!)
Mouser is by far the best.. so go here:
https://no.mouser.com/Semiconductors/Discrete-Semiconductors/Transistors/MOSFET/_/N-ax1sf
Then select all the parameters to match your AO4614.. package, minimum current, voltages etc.. Once narrowed down you will probably have to go into the data sheets to check the switching times. You can then enter the part number into RS and see if they stock them also!
dl324
Joined Mar 30, 2015
18,462
Welcome to AAC!
It would be helpful if you showed us the circuit where it's being used so we can determine which parameters are important.
peterdeco
Joined Oct 8, 2019
484
Quick question David. Why do you need a replacement and not the original? They are readily available from many distributors and cheap. I saw them on ebay at $8.99 for 50 of them.
David64
Joined Dec 25, 2019
thanks for replies, I had seen them via eBay from China at a good price, it was just the months wait that made me start looking for an alternative.
thanks David
dl324
Joined Mar 30, 2015
18,462
