ElectricSpidey
- Joined Dec 2, 2017
- 3,370
I'm fascinated by the fact that you are reading 12 volts with the ring attached.
Are you reading 12 volts at the other ends of the leads?
If the output still reads 12V and the light is not lighting, then it is not connected.I'm fascinated by the fact that you are reading 12 volts with the ring attached.
