Looking for Help Powering 12v LED Ring Light
bramsuer
Joined Jun 21, 2021
9
I am a newbie when it comes to electrical and circuitry. I have an application requiring an LED ring light, and it must be battery powered. The rest of the application (handheld device) requires minimal power, and we have selected 4 AA batteries as the most logical power source. Knowing this puts out 6v, I have been trying to step up the power (6v-12v) using a converter to ensure the light is receiving sufficient power. When I do this, I am confirming the conversion to 12v using the multimeter, but the light is still not working. Anybody have any ideas on what is going wrong? I have hooked the light up to a wall outlet and 12v power pack, and it does work, so the light is not broken.
LesJones
Joined Jan 8, 2017
4,544
Are you sure that you have the polarity correct ? The wire to the light does not seem to have any way to identify the polarity.
Les.
bramsuer
Joined Jun 21, 2021
9
What sort of run time are you expecting from this device?
Light would only be on while circuit is completed (a trigger is pulled), so the LED will not be used all that much. That being said, I don't expect a very long run life either.
My guess. The converter does not have enough current and if you measured the output of the DC-DC converter with the LEDs connected it would be less than 12V and maybe zero.
bramsuer
Joined Jun 21, 2021
9
Without really enough information, I am going to guess the most likely problem is the boost converter not providing enough current. You might have more success adapting something like this: https://www.amazon.com/dp/B07ZQ3X5DL/
thanks for that recommendation. that ring is too big for our application - -max diameter is 65mm.
on the boost converter, I manually adjusted it all the way up to 18v, and still no function from the light, which is why i'm so confused.
Ya’akov
Joined Jan 27, 2019
10,368
If the boost converter cannot produce enough current increasing the voltage will not help. My recommendation was only an example. The idea is get something that runs from 5V rather than 12V.
bramsuer
Joined Jun 21, 2021
9
thank you, i was searching for 5v lights but haven't been able to find quite as good of selection. was hoping there was something simple i was missing that would allow me to charge this 12v light with batteries.
Ya’akov
Joined Jan 27, 2019
10,368
You can steal the ring and power circuit from a 5V light if you can find one the right size.
