Quite awhile back I was looking for a way to make LEDs flicker without having to use an Arduino or program a chip. I am not good with circuit design outside "calculate the resistor needed to make an LED work". Using a flicker LED in series might work if I was using 12v, but won't work well with 3v and 4.5v battery combinations, I came across this thread with (what looked like) a simple circuit showing how to use a 2N2222 transistor and an LED taken out of a tea light / candle to drive a 1W star.
http://brassgoggles.co.uk/forum/index.php/topic,36566.0.html
I wanted to make a basic green 5mm LED flicker, not a star. I bought the transistors and LEDs, thinking I could figure out how to modify it, but the rest of the project I was working on wasn't repairable and I never built the circuit. I'm trying to fix some old Halloween lighting now, and I wanted to do the same thing, except make 3mm warm white LEDs flicker instead of green. Unfortunately when I pulled up the bookmark I had saved, the photobucket with the circuit design had been deleted!
I found a second tutorial here, but I do not know the reason for the resistor values chosen. They don't match what 3 red LEDs in series would need whether they were 5mm or 1W stars. I don't understand how the transistor changes the calculation for the resistors needed or how to modify it for other types of LEDs, or understand the reasoning for having the 45 ohm resistor in front of the transistor circuit with a 10 ohm on the collector.
http://spookyblue.com/spookyblog/build-a-flickering-led-candle-amplifier
I found a third tutorial here that uses a PNP transistor instead of an NPN, again with no understanding of how the resistor values were chosen. I can see using a higher resistor than needed for the flicker LED since you only want it to drive the signal and not necessarily shine at full brightness (since it won't be used anyway). But I don't understand the resistor choice to light up the white LED.
https://www.evilmadscientist.com/2011/does-this-led-sound-funny-to-you/
I have 200 2N2222 transistors and I would really like to try to make this work with what I have, but I understand if it's just not going to work.
Basically: Use a 2N2222 transistor and a flicker LED taken out of a tealight to make one 3mm warm white LED (~3.2v/30mA) flicker, using a 3xAAA 4.5v battery pack. I just wish the circuit diagram on the first forum was still active. I tried making the circuit via the /text/ description in that link, with the 56 ohm resistor on the flicker LED and a 39 ohm resistor on the warm white LED, but the warm white is on steady and the flicker LED doesn't light at all. I also tested it with 120 ohm, 240 ohm, and 1k ohm resistors on the flicker diode.
