The doubled frequency is NOT the output frequency. It is the frequency that is input to the 50% duty cycle generator. As such, in the proposed scheme for a maximum frequency of 1KHz, one would generate the input frequency of 2KHz. Or a range whose endpoints are double that of the output frequency.The frequency cannot be above 1Khz but thanks for the suggestion
It is not so much 0 and 180°, as 90° and 270° (the peak and the trough), but thank you for your help. It is most appreciated.If you want F/2 at (arbitrarily) 0 degrees and 180 degrees, take the signals from IC2A pins 1 and 2. they are complimentary. Tie pins 8, 9, 10, and 11 to GND, and ignore 12 and 13.
Check the 4013 datasheet for its output current ratings, and note that as the output current (either sourcing or sinking) increases, the output voltage margin increases.
ak
LM555 with a 50% duty cycle.Good point.
I have been working to schematics, however they are what I have drawn in my notepad and not easily transferred onto a webpage.
The circuit I used earlier for the 555/4013, I lifted from a site and it was this...
It is not the circuit I am looking for, as it clearly states 1/2 a 1/4 frequency.
It does indeed flip and flop, only F/4 is half the frequency of F/2... as mentioned
*Approximately* 50%, as in post #15.LM555 with a 50% duty cycle.
You are dealing with all square-wave devices and signals, so there are no peaks and troughs in the traditional sense (as with sine waves). The two signals are 180 degrees out of phase with each other, but nowhere in this thread have you indicated that you wanted them 90 degrees phase shifted from the source.It is not so much 0 and 180°, as 90° and 270° (the peak and the trough),
Wouldn't that be done with a "Johnson ring counter"? But it would still not be a sine wave but a square wave.It is not so much 0 and 180°, as 90° and 270° (the peak and the trough)
Hi, as mentioLM555 with a 50% duty cycle.
Hi,You are dealing with all square-wave devices and signals, so there are no peaks and troughs in the traditional sense (as with sine waves). The two signals are 180 degrees out of phase with each other, but nowhere in this thread have you indicated that you wanted them 90 degrees phase shifted from the source.
ak
Feed this input frequency into a D flip flop wired as a T (toggle) flip flop. That is, connect notQ output to the D input. Then, the Q and notQ outputs are your alternating outputs.
Much simpler than the circuit you posted. It only used one flip flop.
It would help if you could also generate a timing diagram, so we can validate any suggestions
Nice idea but it didn't work and I reckon it blew the chipIf you want F/2 at (arbitrarily) 0 degrees and 180 degrees, take the signals from IC2A pins 1 and 2. they are complimentary. Tie pins 8, 9, 10, and 11 to GND, and ignore 12 and 13.
ak
Your suggestion did actually work, until I connected the opto's. Then, only the Q output functioned properly.A complete schematic might help. Draw it on paper and snap a pic to upload if you don't have any schematic rendering software.
The circuit I suggested does exactly that. Mea culpa, I am asking you to post a schematic and I yet to do so. I'll try tomorrow.Your suggestion did actually work, until I connected the opto's. Then, only the Q output functioned properly.
I am sorry, but I don't have how to take any pictures.
Try to see this.
A 555 output of say, 888hz and +/- 50% duty cycle. Let's say 49.9%
In an ideal world, the signal from single pin 3 of the 555 needs to enter a HEF4013 and exit as TWO outputs.
I.e. Imagine two LED's connected to different output pins on the 4013.
One lights up, then the other, then the first, then the other... ad infinitum.....
It does not have to use a 555, nor a 4013. It is just that I am in Brazil and that is what I have right here, right now....
I can try to get an image tomorrow.
If it works until you hook up the opto, then maybe the opto circuit is wrong. But I can't see it.
You've told me that doesn't work. You've rather aggressively told AnalogKid that his suggestion doesn't work.
But you haven't told us WHAT doesn't work. We have no idea what you did. We have no reason to believe that you did what we suggested. What we know is something doesn't work. And we likely believe it's not what we suggested.
Put your image where your mouth is. Post a schematic, or I can't waste any more time on this.
