Looking for a panel mounted duty cycle counter
James55
Joined May 29, 2016
39
Hi all,
does anyone know of a particular unit, or otherwise, where I can find the circuitry to build a digital duty cycle display?
The circuit runs on 12 volts, 1KHz max' and it could include a frequency counter.
I know I could use an Arduino, but was wondering if anyone had any other ideas.
Many thanks in advance.
KMoffett
Joined Dec 19, 2007
2,918
A little more explanation of what you are trying to measure. "Duty cycle" is a ratio of time periods, not something you count.
Ken
James55
Joined May 29, 2016
39
Point taken about it not being a counter....
The circuit runs a stable frequency from between 200 to 1Khz (it is an experiment), yet needs to maintain a 50% duty cycle.
To that end, I already have an adjustable, working system, however it would be nice to be able to read the duty cycle without having to connect
a meter each time.
We can buy off-the-shelf digital displays for amps, volts and temperature etc. so I was wondering if anyone knew of a display/circuit to read the duty cycle, as shown in the image below, only without using an Arduino?
dl324
Joined Mar 30, 2015
18,376
The frequency cannot be above 1Khz but thanks for the suggestion
The frequency would be doubled on the input of the flip flop and halved on the output.
400-2000 Hz in, 200-1000 Hz out. Using a toggle flip flop is a common solution for obtaining a 50% duty cycle.
James55
Joined May 29, 2016
39
Do you mean something like a 4013 connected to the 555 output?
I had thought about using an IR2151 and therefore having no need to read the output...
AnalogKid
Joined Aug 1, 2013
12,166
Mimicking one form of a 555 astable, the 2151 comes close to 50%duty cycle. However, it will not be exact. First, the 555 section output impedance is not symmetrical, so the equivalent timing resistance is different for the up and down half-cycles. Second, the 555 section output voltage is not truly rail-to-rail, again affecting the capacitor charge and discharge times. The datasheet says the range is 48% to 52%.
ak
James55
Joined May 29, 2016
39
ak
I think I'll try the 2151 anyway and see how close I can get
hp1729
Joined Nov 23, 2015
2,304
Hi all,
Count the number of microseconds the signal is high. Count the number of microseconds the signal is low, and divide. Most frequency counters will do this I think. If the question is about a signal you are creating the solution is in the design. Can you post a schematic of the design? Do you have an oscilloscope so you can view the signal?
James55
Joined May 29, 2016
39
Hi, I have no circuit diagram. I am making this up as I go along... Although I do have a scope.
The desired output is two channels 180° out of phase from each other (hence the 50% duty cycle request) whilst both channels run at the same frequency which I wanted to keep below 1 Khz. I want to switch two opto-couplers (4N25), flip - flopping, if you like?
So far, I have been experimenting having a 555 as the signal generator. That part is not the problem.
As I write this, I have a 555 triggering a HEF4013 but output 2 (pin 13) is half the frequency of output 1 - so this is no good....
It failed with aa relay, yet seemed to work using an NPN and PNP back-to-back on the 555 output, until I connected 2 opto's in parallel to the PNP. ?!!!??!!!???
Surely it must be a doddle to have a circuit run at a fixed low frequency whilst flipping and flopping in perfect division?
AnalogKid
Joined Aug 1, 2013
12,166
That should work perfectly if wired correctly, which is why we always need a schematic before we can have an informative conversation.
ak
James55
Joined May 29, 2016
39
ak
:) Good point.
I have been working to schematics, however they are what I have drawn in my notepad and not easily transferred onto a webpage.
The circuit I used earlier for the 555/4013, I lifted from a site and it was this...
It is not the circuit I am looking for, as it clearly states 1/2 a 1/4 frequency.
It does indeed flip and flop, only F/4 is half the frequency of F/2... as mentioned
