Looking for a low frequency dual output oscillator
Ian0
Joined Aug 7, 2020
13,310
Yes I know that, plan not to , I still have a few options on MOSFET, I need to get that gate-source capacitance filled up the fastest, thus thats why I need the current
Are you sure that's wise?
How are you going to suppress any potential ringing between the gate capacitance and any inductance in the drive circuit?
captoro
Joined Jun 21, 2009
207
I guess I will see when I have the board done, Unless you can simulate that? or put a low value 4 ohm resistor on the gate
captoro
Joined Jun 21, 2009
207
I forgot to mention, I didnt realize there was an ISL55111 with complementary outputs. Thank you. Thats going to be an improvement. Too bad its back order on Digikey AND Mouser !
Ian0
Joined Aug 7, 2020
13,310
Presumbaly you have a 1GHz scope? Otherwise you'll find out when the MOSFETs start blowing up.
4 ohms drive and even a small MOSFET with 1nF input capacitance gives a risetime of about 10ns
captoro
Joined Jun 21, 2009
207
Ian, I was thinking about using this MOSFET: ‎CSD18533KCS‎. Because of its similar identical (and fast) fall and rise time . If there is too much ringing occuring I can always add a small gate resistor.
