Looking for a low frequency dual output oscillator
captoro
Joined Jun 21, 2009
207
Anyone knows of an IC similar to the LTC6908 but with lower frequency output?
Looking for a dual output oscillator with complimentary outputs from 0 to 10khz with fast rise time.
That LTC6908 IC would be great but frequency starts at 50khz
Ken
38,827
Use a 555 configured as an astable oscillator, and connect it to a couple of high-speed inverting logic gates, such as the VHC family, to get fast inverted and non-inverted outputs.
Ian0
Joined Aug 7, 2020
13,281
Does it need to be a squarewave?
If so, use the 4047 as @Audioguru again says, because it has a divide by two which ensure that the outputs are really square.
Then buffer with a high-speed logic such as 74AHC04 as @crutschow said if you want 5V, or an MCP1401 if you need higher voltage outputs.
Or if "square" isn't so important, a 555 followed by a inverting/non-inverting driver such as TC4428.
Sorry for the pedantry, but it's "complimentary tea and coffee" but "complementary outputs"!
captoro
Joined Jun 21, 2009
207
The rise time of a 555 is about 100ns, which is slow compared to other options.
Ian0
Joined Aug 7, 2020
13,281
That's why you'd connect it to a couple of high-speed inverting logic gates, such as the VHC family, to get fast inverted and non-inverted outputs.
Ian0
Joined Aug 7, 2020
13,281
thanks, I found the CD74ACT109 which has complementary output. that should do it
but that's not going to oscillate.
and if you just want a buffer to speed up the risetimes there are plenty of simpler choices than a JK flipflop, such as a 74AC14 schmitt trigger.
AnalogKid
Joined Aug 1, 2013
12,280
Do you need the spread-spectrum modulation?
AND - what kind of frequency accuracy / stability / repeatability do you need. Depending on the answers, the whole circuit (variable oscillator plus two-phase outputs) can be done with one 74AC quad gate.
ak
AnalogKid
Joined Aug 1, 2013
12,280
If you look at the 109 internal schematic, you will see that there is some delay between the state changes of the two outputs (skew). What is your tolerance for this? That is, how many nanoseconds of delay between the Q output changing state and the -Q outut changing state can your system tolerate?
Also, for whatever that minimum skew requirement is, is it the same for both edge directions?
ak
captoro
Joined Jun 21, 2009
207
ak
I was going to use the LTC6991 for oscillating, then feed its output to the CD74ACT to get complimentary outputs, then feed that into separate MOSFET drivers.
Ian0
Joined Aug 7, 2020
13,281
Are you planning on putting a resistor in series with the MOSFET gate?
If so, the product of the resistor and the MOSFET gate-source capacitance will limit the rise-time.
captoro
Joined Jun 21, 2009
207
Yes I know that, plan not to , I still have a few options on MOSFET, I need to get that gate-source capacitance filled up the fastest, thus thats why I need the current
AnalogKid
Joined Aug 1, 2013
12,280
Three simple inverters in a hex inverter package will do the same thing with less propagation delay. If the 6991 output signal is good enough to drive one MOSFET driver, then you need only one inverter to produce the other phase.
ak
AnalogKid
Joined Aug 1, 2013
12,280
Yes, but the rated current is less and rise time is higher then the ISL55110 MOSFET driver
The ISL55111 (same datasheet as the 55110) has an inverted B input. With this part, you no longer need a two-phase drive signal.
A - Oscillator - anything that meets your freq and stability specs
B - Buffer - a single inverter or non-inverting buffer, anything that meets your edge specs
C - MOSFET drivers - ISL55111 with both inputs connected to the buffer output.
Again, if your frequency stability requirement is not stringent, a single CMOS gate chip such as a 74AC14 will do parts A and B. If you use a gate part such as a 74AC132, you can gate the oscillator on and off if needed.
https://www.onsemi.com/pub/Collateral/MC74AC132-D.PDF
ak
