Hi guys, this is my first post on this forum
ill try my best to explain my problem, so in advance sorry for wrongly used terms
my 2.1 system is making loud buzz noise on both woofer and tweeters. after opening it ive discovered some issues.
z533 2.1 system with blown 'deviders' (not sure how its called) for 3.5mm and RCA ports for audio signal input (ive attached pics).
ive notices that devider circuit around it its blown, 2 caps, 2 resistors and 1 unknown component in the middle marked with FB3(for 3.5mm jack) and FB4(for RCA). u can see that for 3.5mm jack its completely blown from pcb.
ed more info or pics
thank you
- on pcb 3.5mm jack is market as J4 and RCA as J5
- ive purposely took picture behind light so u can see traces going to that blown 'devider'
- resistors are 7.5k ohms, for caps and component in the middle i am not sure (need ur help about that)
- suggestion to check any other component that could be damaged also
ed more info or pics thank you
