Logic gate using 555 timer(toggle switches and led circuit)
meepmorp
Joined Apr 24, 2021
I wish to have a circuit such that, when the first toggle switch is on, led turns on continuously, and when both are on, it blinks, when both are off, it is off. I have tried a lot, but I am unable to do this
Irving
Joined Jan 30, 2016
5,195
Switch 1 (SPST, NO) connects power to circuit.
Switch 2 (SPDT, CO) common connected to LED, NC contact (off) connects LED to output of switch 1, NO contact (on) connects LED to output of 555.
AnalogKid
Joined Aug 1, 2013
12,284
OR ...
Switch 2 (SPST, NO) connects Reset input to Vcc. Resistor connects Reset input to GND.
LED (and current limit resistor) anode to Vcc; cathode to 555 output.
ak
AnalogKid
Joined Aug 1, 2013
12,284
Please add "anode" and "cathode" to the LED descriptions.
ak
38,871
That works too, though does depend on whether 555 sinks or sources current in LED.
Yes, the LED would be need to be connected between V+ and the 555 output for that to work.
The resistor should be no more than about 600Ω to insure the 555 is in the Reset state.
AnalogKid
Joined Aug 1, 2013
12,284
First pass at circuit for post #5. R1-C1 set the flash rate. To reduce parts and clutter, this circuit has a fixed 50/50 on/off ratio. C2 is power supply decoupling. It is a bit larger than normal because the 555 is switching the full LED current.
As above, R2 is less than 600 ohms for the bipolar 555. For the CMOS 555 in this schematic, it can be increased to almost anything. for example, it can be whatever value the R1 timing resistor is. With the CMOS 555, LED current must be limited to 50 mA max.
ak
Ian0
Joined Aug 7, 2020
13,298
Eleven replies later and we still don't know what is supposed to happen when the second toggle switch is on but the first is off?
Irving
Joined Jan 30, 2016
5,195
If the LED is off its a don't care condition... Or so everyone has assumed, since there's not many obvious alternatives!
Ian0
Joined Aug 7, 2020
13,298
He could have meant that if one switch is on (either switch) then the LED is illuminated continuously but if both switches are on it flashes.
AnalogKid
Joined Aug 1, 2013
12,284
When you changed the LED-555 connectoin for the correct steady-state logic polarity, you forgot to reverse the LED because the current direction changed. The LED cathode is tied to Vcc.
ak
