Logic Diagram using 4-bit Parallel Adder and NAND Gate
Eehit
Joined Nov 1, 2020
How to design a multiply-by-6 circuit given a 3-bit binary unsigned value ABC as its input. The circuit generates a 5-bit binary number S4 S3 S2 S1 S0, and an output V.
Since the circuit may not accommodate certain input value owing to the limited number of output bits, such an input value is deemed invalid, and the corresponding output will be don’t-care values. The output V is used to indicate whether the input value is valid or not: 1 if the input value is valid, or 0 otherwise.
Eehit
Joined Nov 1, 2020
So I am not able to figure out how to use the 4 bit parallel adder and the NAND gate to perform multiply by 6 operation. I have been able to solve the truth table and SOP expressions for each of S0, S1, S2, S3, S4. But I am just not able to think how to design this multiply by 6 circuit... I also thought about using this concept like:-
Suppose I have X as my input. Then I shift the binary input of X by one place which shall make it 2X. I shall then add another X to 2X to make it 3X. Then I shall again shift the binary number 3X by one place to make it 6X. This way it will get multiplied to six times.
WBahn
Joined Mar 31, 2012
33,315
What you have described here does not produce the required V output.
Eehit
Joined Nov 1, 2020
You are to design a multiply‐by‐6 circuit given a 3‐bit binary unsigned value ABC as its input. The circuit generates a 5‐bit binary number S4 S3 S2 S1 S0, and an output V. Since the circuit may not accommodate certain input value owing to the limited number of output bits, such an input value is deemed invalid, and the corresponding output will be don’t‐care values. The output V is used to indicate whether the input value is valid or not: 1 if the input value is valid, or 0 otherwise.
Let's implement the multiply‐ by‐6 circuit using a 4‐bit cascade adder (parallel adder). The 4‐bit adder is used to generate the 5‐bit outputS4S3S2S1S0. [ Hint: Think in binary]
For the output V, you are to use a NAND gate to implement it.
Eehit
Joined Nov 1, 2020
Welcome to AAC!
Please post the entire text of the problem.
WBahn
Joined Mar 31, 2012
33,315
You are given a HUGE hint and told what the NAND gate is for -- it is to implement the V output.
But forget about that for the moment, show your best attempt to implement the circuit. You've described how you would approach getting the Y = 6X output, but a sketch of the schematic you would use would be nice. Also show your best attempt to come up with the V output.
dl324
Joined Mar 30, 2015
18,490
Are you only allowed to use 1 4-bit adder? Can you use half adders and AND gates?
WBahn
Joined Mar 31, 2012
33,315
It sounds like he is expected to use exactly one 4-bit adder and exactly one two-input NAND gate. There are two ways (at least) of doing it with just those two blocks.
