Solving boolean expression using annihilation rule
BeginnerLevel1
Joined Jan 28, 2020
Suppose I have a function described as: AB+(1+AB+CK+G) Can I asssume that the expression I have inside the brackets is equal to 1?
annihilation rule:0x=0,1+x=1
I need to reduce the function in order to have a minimum of logic gates.
WBahn
Joined Mar 31, 2012
33,326
If there any way for the expression in parens to be anything other than 1?
If you are only allowed to apply that rule to two operands, then do it incrementally.
Consider
1 + A + C
(1 + A) + C
1 + C
L General Electronics Chat 1
V Homework Help 8
