I see the truth tables for both NAND and AND on wikipedia. I'm not sure what I'm missing?
Make a truth table for YOUR circuit. It will help you figure out what logic operation it's doing.I see the truth tables for both NAND and AND on wikipedia. I'm not sure what I'm missing?
When you say '1,1' the first time you appear to be talking about the two inputs to the AND gate resulting from having '0,0' being the two inputs to the two inverters, respectively. Hence there will only be a single output from the AND gate (it takes two inputs and produces a single output). I think you are getting yourself confused because you won't take it step by step.Hold it, based on what I see on Wikipedia, the 1,1 when it goes through the AND gate is then 1,1 but then it goes through the NOT gate again which makes the answer 0,0. Did I finally get it! I'm starting to kinda get it.
PF, I want to see you draw a truth table for your circuit by yourself. I honestly think it will help.I'm not following, again I'm just barely starting to understand this finally. If the output as we figured out is 0,0 right, what is the next step?
As stated in my post, I worked the ORIGINAL problem from the first post in this thread. I did NOT work the current problem he is working on -- just look at the attached image.PF, I want to see you draw a truth table for your circuit by yourself. I honestly think it will help.
WBahn, I was trying to get him to do the work himself, rather than just give him the answers. No offense, but I'm actually glad he didn't follow your post![]()
Right i just caught that, I reread the question and I missed the second half. Its 0,1.PF, I want to see you draw a truth table for your circuit by yourself. I honestly think it will help.
Back to PF: Draw the truth table and upload an image here please. We'll take it one step at a time.
Oh, and the output of the circuit for (A=0 B=0) and (A=0 B=1) is not 0,0. You seem to be thinking that 0,0 is a single answer for one of the conditions ( (A=0 B=0), for example). That's not it. Each character corresponds with one of the conditions. The first character (before the comma) means the answer when A=0 and B=0. The second character (after the comma) is the result of A=0 and B=1.
Oh I'm sorry. You mean the circuit in post 3? I was thinking you were talking about the one in post 9. I apologize for that....As stated in my post, I worked the ORIGINAL problem from the first post in this thread. I did NOT work the current problem he is working on -- just look at the attached image.
Ah, much better!Right i just caught that, I reread the question and I missed the second half. Its 0,1.
I assumed that's what you meant by that statement.Now for that same circuit the type of logic created is NAND right?
Then, go through one by one. Find the output (X) for when A and B are 0, and write that under the x, right next to the input conditions.A B X
0 0
0 1
1 0
1 1
Yeah I got ahead of myself. So I think we are pointing towards this overall being an NOR/NOT OR logic?Yeah, post 3 (the one he was talking about in post 1, but didn't post the actual circuit until a bit later).
No problem. We are on the same page with regards to guiding him to the answer on his own.
@pf
I'm glad you got it. Now, what is the name for the logic function that this circuit implements? Hint: it implements one of the basic logic functions, just like the first one implemented the XOR function).
PF, they are asking for the equivalent logic operation. It's not asking what operations make up this circuit. It will be ONE answer. If you make the truth table, like I described before, and compare it to known truth tables, it'll help you figure out which operation is equivalent to your circuit.Yeah I got ahead of myself. So I think we are pointing towards this overall being an NOR/NOT OR logic?
PF, what is it that you have against making the truth table as we have been constantly trying to get you to do? Draw the damn table! Do the best that you can and post it and then we can see, exactly, where you are having difficulty. It's fine to try to talk through the problem verbally at first, but if that doesn't pan out quickly, you need to step back and work the problem explicitly, step by step.Yeah I got ahead of myself. So I think we are pointing towards this overall being an NOR/NOT OR logic?
PF! I walked through creating the truth table for the original problem step by step! All you have to do is do what I did, only do it for the circuit you are working on now.OK, explain to me how to me how I'm created a truth table out of this? Based on my own logic here, and process of elimination its got to be an AND operation, no? Still explain to me how do I create a truth table here?
So take it step by step!I'm just not getting it. Nothing is making sense to me now.
| Thread starter | Similar threads | Forum | Replies | Date |
| R | Help with a CMOS logic gate circuit | Homework Help | 5 | |
| T | Logic gate help | Digital Design | 16 | |
| A | Help with logic gate circuit problem | Homework Help | 13 | |
| V | Logic gate circuit HELP | Homework Help | 10 | |
Pls help with logic gate | Digital Design | 10 |
