Help with a CMOS logic gate circuit
raziell122
Joined Mar 28, 2023
85
Hello everybody!
I started working on the following exercise, in the first section they asked me to complete a truth table that contains the working conditions of the transistors, and when I finished my table I saw that the solution for this was different.
I would like to know please how is it possible that Q12 can be 'ON' while Q11 is 'OFF' as the solution shows in the rightmost column.
The circuit:
My table:
The table of the solution:
Thank you in advance!!
WBahn
Joined Mar 31, 2012
33,281
Keep in mind that tables like these are treating the FETs as simple voltage-controlled switches that are either ON or OFF based on the gate voltage. Whether the source of an NFET is floating or not doesn't matter in terms of the digital functionality.
The state of Q11 is therefore solely dependent on inputs A, B, and C, while the state of Q12 is determined solely by input D.
raziell122
Joined Mar 28, 2023
85
Thank you that was very helpful!
What about if it was a TTL circuit? only BJTs.
raziell122
Joined Mar 28, 2023
85
TTL circuits are a bit harder to analyze in detail, but the same basic idea applies. For instance, here's the classic TTL NAND gate:
Hey dear friend,
may you help me again please to understand a similar case just in TTL logic? the last explanation of CMOS was very helpful!
I have the following logic gate:
And they are asking me to complete the same truth table.
I created the following table, and the solution one below, I marked with a green color the differences between them.
I just want to know if it is possible that Q4/Q5 will be in SAT mode while Q6 is OFF, just as you told me in CMOS.
