Logic gate circuit HELP
vermerker
Joined Dec 15, 2017
7
Hi, I've made a truth table for this circuit and have come to the conclusion its a buffer for B but I'm not sure this is right. Can someone let me know how they would have gone about it. Is it another logic gate, arithmetic function or memory?
dl324
Joined Mar 30, 2015
18,491
Welcome to AAC!
Put labels for A, B, and Z on the schematic.
Are we to assume that a HIGH from the OR gate turns the light on?
vermerker
Joined Dec 15, 2017
7
Welcome to AAC!
Yes and I think I initially did the truth table wrong and now think the circuit is equivalent to a buffer for B. Is there any other useful function of this circuit?
WBahn
Joined Mar 31, 2012
33,324
If it's a buffer for B, that means that A has no effect on the circuit.
But what if A is HI?
vermerker
Joined Dec 15, 2017
7
If A is LO when B is HI then assuming Z starts from LO it will change to HI. So so I assume that Z is still at HI? if it is then it will remain there? So is it acting as memory for B?
WBahn
Joined Mar 31, 2012
33,324
If has a memory aspect to it, but whether "acting as memory for B" is a reasonable description depends on what, exactly, that phrase means. If it's memory for B, what purpose does A serve?
Are you familiar with RS latches? Can you recast this circuit into one of the classic latch circuits?
vermerker
Joined Dec 15, 2017
7
Thank You for your help, I have run a simulation of this circuit and understand it mostly. I can see that it stores the value of B when A is LO and B is HI even after B is reverted to LO as long as A remains LO Z is HI. The same applies the otherway A can reset the output to LO by changing it to HI and the circuit remains at LO even if A is changed to HI.
Can you help me on this circuit? is there a connecting function of X,Y or are they just separate logic gates XOR and NOT for B?
