Hi everyone, Im busy with an assignment and want find out if my truth table is correct for this diagram attached? Or at least if Im on the right track? Thanks
How did you fill the 2nd table?Hi everyone, Im busy with an assignment and want find out if my truth table is correct for this diagram attached? Or at least if Im on the right track? Thanks
It looks like Table 2 should have had C, B, E as its headers, not C, D, E. Then, use standard logic to fill in Table 3.Not sure I understand.....table 1 and 2 had some information in it already......only 3 was completely empty. I do suspect I might have an issue with table 2, but Im not sure.
Hmmmm that makes sense as I struggled to figure out why it was split that way.......I will bring this up with the tutor as well.It looks like Table 2 should have had C, B, E as its headers, not C, D, E. Then, use standard logic to fill in Table 3.
I agree. And Table 3 only needs the first 4 lines, as the next 4 lines are repeats. And, to be picky, the D and E columns would normally be listed, in order, as 00, 01, 10, 11.Marked
A+
BUT . The tutor will be looking on this site, so C- , unless you explain to them why the table changed.
