The sparkcore's PWM runs at 500Hz, so that should be fine.
After a bit of chatting with the sparkcore's engineers, they lead me to a IRLB8721PbF MOSFET which will work well with the cores 3.3v.
The diode I'm going to order - IN5819
What small poly cap????
In this case should I put the power cap between the S pin and the red +pwr wire?It does need a power cap (470uF) adding between the transistor E pin (gnd) and the red +pwr wire.
Since you we had originally talked about using a TIP120, which had a different pinout, would you mind making a suggestions for this new FET?From a noise viewpoint you could make a couple of tweaks. I would solder the diode directly across the motor terminals to keep PWM recirculating current local to the motor, and I would add a small poly cap from B-E of the transistor (parallel to your 1k resistor).
