Lock Pick
AnalogKid
Joined Aug 1, 2013
10,564
I like electronic locks because they are relatively pick-proof. And if you eliminate the keypad and reduce things to a single button, that looks like the definition of "impossible". I'm working on a door unlock system based on a rhythm pattern entered with a single, unmarked button, probably a small disc on a plunger that activates a SPST momentary switch. With a 4 to 8 step press-release pattern that must be completed within a specific time *window*, I think this will be secure.
But what if ... What if an evil doer got a copy of the schematic? Could he decipher the correct input pattern? Can you? What do you have to do at SW1 to cause U1Dpin11 to change state for 0.5 seconds?
Note: power decoupling, transient protection, unused gate termination - all done.
ak
Hey, a co-worked asked me if could turn the copier on. It shut down at 5:00 and you needed a 4 digit code. His request was reasonable, so I said I'll try. I had the code in about 10 minutes. I was given a briefcase with a 3 dgit number. Open in about 5 minutes. Tried 2 numbers based on who it belonged to.
I can open simple L-R-L type combo locks like Master in 20 minutes. It takes me a little longer to get the combination, Self-taught.
ElectricSpidey
Joined Dec 2, 2017
2,593
That pathetic huh?
Well my thinking is the first push will bring the 4017 out of reset, then 3 more will advance the counter to Y3, then one more will advance to counter to Y4 and must be held to overcome the RC created by R4 & C4.
AnalogKid
Joined Aug 1, 2013
10,564
I did. SW1 is an industrial type, not a gold-contact, 10mA max., delicate little flower. C1 is a MIL-grade MLC. I might swap D1 for a 1N4002; I have some getting dusty.
ak
MrSoftware
Joined Oct 29, 2013
2,126
Embedding the code in hardware is not a good idea. It is reasonable to believe that at some point you'll need or want to change the code. Maybe the wrong person learns the code somehow, the lock changes owners, any number of reasons. If it were my lock, I would make it possible to change the code somehow. If you want to do it all in hardware, maybe add a DIP switch that you can toggle to select the code. Or add a little micro processor and put the code in software. Any way that allows you to change the code without having to completely redesign and rebuild the lock.
Side note; for the locking mechanism itself; use a worm drive gear and solid circuitry to drive it. Anything held by a spring can be jarred to unlatch, mechanical relays and plunger style solenoids are susceptible to strong magnets.
MrSoftware
Joined Oct 29, 2013
2,126
Ah cool! Should you want to do it in software, there is existing arduino code out there. It's used for the escape room "secret knock" type puzzle, the player knocks a pattern on a door and the arduino compares the pattern to the pre-recorded pattern. You can just replace the piezo knock sensor with a button.
BobaMosfet
Joined Jul 1, 2009
2,081
ak
As a former locksmith, and very knowledgeable one the subject, while I cannot answer your specific question I will answer a heuristic one- other locking systems employ this technique, but usually with more than one button, increasing the level of difficulty. The problem most users have, which makes them dislike this, is the time aspect- even if you know the code, you can be forced to attempt it 4 or 5 times because you're just 'off' that day for whatever reason- most people don't have perfect timing, so timing related things can become a nuissance. IMHO.
AnalogKid
Joined Aug 1, 2013
10,564
As an experienced amateur lock-person, I completely get your point. And disagree.
Nothing is more ambiguous than a single round button. Not doorbell-looking, not security-company looking, not explosive-proof looking; something with zero personality (read: clue). It is difficult to convey exactly how little information is given away by a single, small, round, plastic button.
Press it - nothing happens
Tap it a few times - nothing happens
Hold it down - nothing happens
Tap it a few times than hold it down -nothing happens
That exhausts the thinking abilities of 99.9996% of the earth. Ahh, but you are not in that group. You are a trained, experienced, professional. So, what would you do next? Note that your professional eye tells you that the button is not a part of any standard switch you know. And it isn't; it is the head of a small plunger. Internally, the switch is 1" off to the side, but you don't know that.
ak
Papabravo
Joined Feb 24, 2006
20,383
If everybody was a CW fist then keying a long password in Morse code would have a definite attraction. I could even see making the paddles explicit and requiring Iambic-B keying. No run of the mill crook would have much of a prayer.
AnalogKid
Joined Aug 1, 2013
10,564
Not in this case. It is an auxilliary system, I'm the sole user, and it's a rhythm patern I created.
It's a rhythm pattern with false entries. Even if someone were secretly looking over my shoulder (in my driveway?), they would not know what they were seeing. BTW, incase someone on this forum wants to raid my garage, the above schematic is not complete. There is additional timing and gating.
When I kick, the system can be abandoned in place without affecting the normal buttons that the house came with.
ak
