2 x 12v Lock Solenoids
codepuncher
Joined Jun 4, 2017
26
Can someone please recommend a handheld battery pack that can trigger 2 of these 12v Solenoids with a single jack plug.
Or please show me how to connect batteries to do the job.
The small round 12v shown does not trigger a single solenoid and my attempt to join 3 of these to run 2 solenoids have failed.
The 9v battery does trigger the solenoid but when i combined 2 together it worked a couple of times and then stopped.
Alec_t
Joined Sep 17, 2013
15,158
How much current does a solenoid need to operate reliably, with sufficient pull/push power for your needs? The greater the current the quicker you will flatten any battery.
PP3 and key fob batteries won't last long or work well, as you've discovered. You may well need a small sealed lead-acid battery.
Do you have any specifications supplied with the solenoids?
BobTPH
Joined Jun 5, 2013
11,662
If a PP3 only operates them a couple of times, I would guesstimate the total current is more than about 1A, or 500mA each.
The way to determine it is to measure the current. That is best done by using a battery or power supply that is more than sufficient. Then we can come up with a good battery recommendation. Also we would need to know how long the solenoid is held on and how often it is used to estimate battery life.
I am puzzled by your use scenario. Opening a lock by supplying power through a jack is not very secure.
codepuncher
Joined Jun 4, 2017
26
Thanks.
In my application I could install manually operated latches but was hoping solenoids would be a lot snazzier.
As it would cost a lot to hardwire multiple rooms with power i was hoping the operator could carry the power supply to each lock, which would only be energised for a few seconds at a time.
38,864
A 9V battery will not prove 350mA for very long.
Suggest you use nine 1.5V AA or C alkaline batteries in series, for energizing the solenoid.
If you want rechargeable, then use 10 AA NiMH batteries in series.
WBahn
Joined Mar 31, 2012
33,263
Thanks.
So... instead of simply activating a latch by hand, they have to carry around a power supply with them? I'm guessing that your operators are going to tire of your snazzy solution pretty quickly.
MaxHeadRoom
Joined Jul 18, 2013
30,854
I would look into radio control actuators, you even have the opion of radio remote control, I have used these in the past and do a pretty good job .
codepuncher
Joined Jun 4, 2017
26
Thanks to everyone that commented.
The power pack worked but as WBahn pointed out it turned out to be too big to lug around.
I built a prototype that has the battery attached to the frame and 2 tactile switches which open either solenoid.
Cheers guys.
