Between 0 and -3.3vwhat is the designed (expected) input voltage range?
That was actually my doubt and what i didn't understood when i connected it, i connected the positive terminal on the + supply terminal of op amp and the negative terminal in the - supply terminal of the op amp (to create 18v potencial difference). The ground ( junction of your two batteries) was not connected to anything, but the +9V -9V are reffered to ground but i don't know where should i connect ground?Do that again, but this time make the junction of your two batteries the ground.
Bob
Any OpAmp, with this setup will give an output of 0 volts.So, i want to use an Op Amp with inverting topology to invert -3,3v into 3.3v (gain of -1). when i simulated it as in the figure i've used single power supplies and it worked (even with 5v in simulation). But in the practice i've tried 5v,12v and 15v single power supplies and none of them made the op amp invert the signal. I've tried also with 2 9V batteries (connected in series) but it didn't work neither (i don't have a dual power supply). Apparently some people manage to make it work like this in the past. I also tried to make a non-inverting topology and voltage follower and none of them worked.
Is this failure related to the supply voltage? do i really need to get more voltage rail to rail?
Also, can i invert an negative voltage with a single supply op amp?
If so, what are the best op amps to do it?
Only if the opamp is configured as a unity gain amp with a negative feedback resistor equal to the input one.An op amp with positive input grounded, and -3.3v to 0v input through a resistor to the (-) input will cause the op amps output to swing between 0 and 3.3v.
No, the inputs are not allowed to go below-0.5V.An op amp with positive input grounded, and -3.3v to 0v input through a resistor to the (-) input will cause the op amps output to swing between 0 and 3.3v.
You'll be fine with a 0-5v single supply. A TLC272 is a low cost.
or, here is an even more modern version... (but not available in through-hole)...
https://www.ti.com/lit/ds/symlink/tlv9102.pdf?ts=1638499522900&ref_url=https%3A%2F%2Fwww.ti.com%2Fproduct-folders%2Fcompare%3FfamilyId%3D1562%26parts%3DTLC272%2CTLV9102%26lang%3Den%26source%3Dprodfolder
Think about it, the voltage source, -3.3v, the opAmp output +3.3v, two resistors in between in a unity gain amplifier, you get zero volts to match the voltage at the (+) input. The inputs never see a negative voltage.No, the inputs are not allowed to go below-0.5V.
Bob
True, but how much gain would you want (need) from an input signal with 3.3v range?Only if the opamp is configured as a unity gain amp with a negative feedback resistor equal to the input one.
- one could insure they specify an op amp that is reasonably fast vs the input signal so the output never lags input by more than 0.3v. OrIn the steady state yes, but what happens before it reaches the steady state?
Bob
And i'm actually doing that sir. I thought that i should make an voltage divider to get a max of -0.3V in the inverting input and a certain gain to get the 3.3V in the output but apparently i don't need that, the LM385 can invert 0 - (-3.3V) in 0 - 3.3V (gain of <1). However invert a positive signal into a negative one is not possibleSome people were wrongly thinking that you were feeding -3.3V to the inverting input of the LM358 that exceeds the maximum common mode input rating of -0.3V. The LM358 does not have a negative supply.
But the opamp has negative feedback so then the - input is very close to its + input of 0V and its output correctly goes to +3.3V.
The LM358 can do it but the LM741 cannot because the LM358 has PNP inputs that work at 0V but the LM741 has NPN inputs that work only above +3V or +4V.
by Don Wilcher
