Hi everyone,
Picked here because I think I have a power supply problem. (apologies if I guessed wrong).
I have an ATMEL avr 328pa chip and a lm35 temperature, a irfz44n and a 10ohm resistor (for heat).
My problem is that my lm35 analog signal changes as I turn on / off my heater. it jumps up and down by about 1V as that transistor ticks on and off.
The 1 power supply (5v) supplies power for everything. it's a little switch mode power supply (10W max it says).
I get the same problem if I only have the lm35 and the resistor on the same 5v power rail.
Of course I'll do a circuit if you like, but I think it's simple enough you get the idea.
If some could shoot the breeze I'd really appreciate it. I'm a tad stumped.
