Heating 2200w induction coil with pid controller. ..#2
vik108
Joined Jun 18, 2026
Dear Friends,
I am from a Charitable NGO feeding mid-day meals to school going children across India. We are working on a temperature controlled Induction heating cookwares like Cook top, boilers, Wok, brat pans etc., Basically on the concepts of Multi-zone induction wok — IGBT zone switching, PID temperature control, and zone-level wall temperature sensing. I have specific requirements like the below
  • Mutual coupling between concentric coil zones — has anyone implemented DSP-based cross-talk cancellation on a dome coil?
  • IR thermopile at 3–8mm range looking upward at a SS vessel base — emissivity calibration approach?
  • PID tuning for a large thermal mass vessel — any practical experience with anti-windup strategies for induction heating?
Attaching few files for your reference. Kindly suggest some practical design implementations and any leads who can render technical support at India
Mod: created new thread, Link to old thread
https://forum.allaboutcircuits.com/...n-coil-with-pid-controller.122175/post-979439
38,946
Have you considered Fuzzy Logic control, which does not have a integrator that is subject to windup.
Fuzzy Logic also can generally handle non-linear and hysteresis system characteristics better than PID which your system is likely to have, as PID is predicated on the system having a linear response.
Here's a tutorial on Fuzzy Logic, if interested.
28,595
How precisely does the temperature actually need to be controlled?? I have been very successful holding an oil tank temperature within +-2 degrees for many hours. Since the oil was circulating thru tested items the heating method was forcing it thru an orifice, with a bypass valve for whan it was not heating. The temperature control logic was ON/OFF with a 5 second interval and one degree of hysteresis. So control was either on or off at five second intervals. It was a commercially available controller, standard product. We did use a solid state control relay and the triac on/off connection to the controller. The only analog part of the system was the thermocouple.
28,595
This system is very much different from the oil tank system. I undrstand about induction heating, but we have no information at all as to what " temperature controlled Induction heating cookwares like Cook top, boilers, Wok, brat pans etc. " actually means. So here is a very specific question: Is the heat produced and applied in an ON/OFF manner??
OR, is the heat applied in a variable manner?? THAT is very important to know!!
PWM on/off heating on a cycle time of a few seconds would be a fairly linear variable.
Is the temperature to be controlled by measurement and feedback, or by setting the rate of heat application?? BOTH are used in everyday cooking by most people.
Probably only ON/OFF duty cycle is available. Linear control gets complex very quickly.
Really, is the temperature to be sensed at all?? THAT is a vital consideration. OR is it cooks judgement???
28,595
It is certainly an interesting topic! My first question would be about efficiency. In particular, what other piecesof the system, aside from the pans, gets hot?? The next question is about heat transfer: It looks to me like only the pan bottom gets heated, which is quite different from a gas stove, where the pan sidesalso get quite hot.
What looks quite certain is that whatever is beeing heated will only be heated at the bottom, so constant stirring, or agitation will be mandatory. Heat transfer by conduction in foof cooking is terribly inefficient and totally uneven.
