LM317 with automatic low cut off
bend94
Joined Feb 15, 2016
46
I am building a simple DC 12v DC in 9v DC out.
I have been using an LM317 and its been fine.
Now I require the output to cut out if the input voltage drop below 10v.
With a draxning please
Thanks in advance for your help!
12,281
To do this you will have to add a comparator to the input. Why don't you sketch up a block diagram or schematic for us to review.
Also, what do you mean by "cut out"? An LM317 has a minimum output voltage of 1.25 V. You can not turn the output down to zero volts without more modifications to the standard regulator circuit.
hp1729
Joined Nov 23, 2015
2,304
I think what he is looking for is the output to go to zero, not just go unregulated or drop to 1.25. Disconnect the input if it drops below 10 V?
Wendy
Joined Mar 24, 2008
23,856
Something you need to be aware of, the LM317 drops around 2V just doing its job. So if you have 10V in you will have 8V or less out.
There are families of more modern 3 terminal regulators that drop a lot less voltage. A good resource on this site is Components Selection Guide.
If you want I will draw something up to get you started. I suspect you need to address the other problem first though.
Just a thought, a simple zener circuit might work better for the regulator, depending on what your current requirement for your circuit is.
bend94
Joined Feb 15, 2016
46
Hi again
Please find my actual electronic device that i am using
I power my arduino with solar energy. it is working correctly till the battery has enough energy.
My goal is to stop powering my arduino when to battery is to low
Because with this actual LM317 when battery power is too low
the arduino is powerup / powerdown / powerup / powerdown all the time.
I want to stop when low power to avoid damage on my arduino.
Please help
thanks
Dodgydave
Joined Jun 22, 2012
11,395
You can use a TL431 programmed zener and p_fet or opto coupler to turn off your Arduino, you set the desired voltage using two resistors.
bend94
Joined Feb 15, 2016
46
i will like arduino to stay off until sunshine and battery is recharged enough to power the arduino
so not manually but if possible automatic
thanks
12,281
To do what you want requires two things, a comparator to sense the voltage out of the Regulator, and either a power switch or a control signal output that shuts down the system. What is the circuit or device inside the box called Regulator? If this has a shutdown control pin, it makes things easier.
Automatic restart is not a problem. Do you want the system to restart as soon as the solar panel output is high enough to run the system, or wait until the battery is recharged enough?
bend94
Joined Feb 15, 2016
46
my device will be connected to the solar regulator output .
This output deliver 12V DC . Well i would like to restart when the solar output is delivering 12V DC
bend94
Joined Feb 15, 2016
46
The Regulator is a solar regulator without any shutdown control pin
Is it possible to do so, with a NE555 ?
Alec_t
Joined Sep 17, 2013
15,157
It's possible, but a comparator IC such as the LM339 would be much more convenient since it is easier to define reference voltages.
bertus
Joined Apr 5, 2008
23,009
The NPN transistor will short the output of the regulator and cut the poser for the 555.
This circuit will probably oscillate.
Alec_t
Joined Sep 17, 2013
15,157
Same problem with a relay, if you use it to short the output of the 7809.
There is also some uncertainty as to the switching thresholds in that circuit, since if the 7809 input drops below the point where regulation fails, the 7809 output will drop too, and so the thresholds will be 2/3 of ??? and 1/3 of ???.
