LM317 Variable Power Supply
Nikki Marie
Joined Apr 25, 2019
I am trying to post a question about the lm317. I just want to know what size transformer for lm317 at full 30v. I know its a 24vac transformer but is it 1 amp or 5 amp transformer? I also know the datasheet says 1.5 amp output, but I am a newbie so that means nothing to me in regards to my question.
38,946
The transformer needs the current to be derated about 50-60% for a DC output, so for 1.5A output, the transformer rating should be at least 2.5Arms.
bertus
Joined Apr 5, 2008
23,031
With an 24 Vac transformer the input voltage of the LM317 will be about 33 Volts max.
What output voltage range is needed?
Keep in mind that a lower output voltage will result in more heat on the LM317.
A heatsink will be essential when going lower in output voltage at higher currents.
Bertus
dl324
Joined Mar 30, 2015
18,522
Welcome to AAC!
24VAC is a little low for a 30V output.
DC will be about 24*1.414 - 1.4 = 32.5V. The drop out voltage for LM317 is a couple volts at 1A. That'll require a large filter cap because you'll have little tolerance for ripple on the input.
From NatSemi datasheet:
