LM317 Schematic Voltage and Ampere
JustMe234
Joined Feb 25, 2017
68
How can adjust Voltage and ampere from LM317 i need i schematic if somebody have it.
I must be run about 1.2-30V maybe 1.5-2 A as much as LM317 can support
Thank you.
wayneh
Joined Sep 9, 2010
18,184
Take a look at the data sheet. While the LM317 might handle 1.5A (with a good heat sink and a low voltage drop), and can handle an input high enough to give a 30V output, it can NOT survive an input of 33V, an output of 1.2V, AND a current of 1.5A. The power dissipation by the IC is the voltage drop times the current, for instance a 33V supply dropped to 3V output at 1.5A would require dissipating 45W in the LM317!! It cannot come close to that. Fortunately, it will protect itself but it's not a great idea to rely on that for a design.
38,946
You may want to go with an LM350 which is good for 3A maximum.
But you would still have the power dissipation problem that wayneh mentioned.
You would likely need a fan-cooled heatsink, such as used for PC CPU chips along with the TO-3 cased device.
Dodgydave
Joined Jun 22, 2012
11,395
Go for the Lm338k, higher power capability,
if you're wanting a variable voltage and current limit,why not go for the LM2596 buck chip, less power wasted at lower voltages, plenty ready-made ones on ebay.
JustMe234
Joined Feb 25, 2017
68
I have one off these and they are good for small things but i need something more powerful.
Recently i order this DC-DC boost converter(showed in pic) and it work only for 5 min with a 100W led at 32V- 2A and then doesnt turn on anymore.
I need to build a power supply that can handle much more power to run those LEDS.
