LM317 maximum output current capped at 840mA in LTSpice
jjjjjjjjjx
Joined May 19, 2018
I made a simple circuit to convert 13.5V to 5V in LTSpice.
I used step function to step through different load resistors from 1ohm to 10ohm in 0.2ohm increment.
The result shows that, the output voltage begin to drop when the load resistance is below 6 ohm or lower.
I then plotted the V load vs I load and found the V load begin to collapse when I load reaches 840mA.
From all the datasheet of LM317, I thought its maximum current output is 1.5A, what did I do wrong?
attached: Untitled.png
jjjjjjjjjx
Joined May 19, 2018
hmm, interesting, the only differences are:
(1.4A top)
R26 32 3 .1
.MODEL QNL NPN(EG=1.22 BF=80 RB=100 CCS=1.5PF TF=.3NS TR=6NS CJE=2PF
+ CJC=1PF VAF=100)
.MODEL QPL PNP(BF=40 RB=20 TF=.6NS TR=10NS CJE=1.5PF CJC=1PF VAF=50)
VS
(0.8A top)
R26 32 3 .06
.MODEL QNL NPN(EG=1.22 BF=80 RB=100 CCS=1.5PF TF=.3NS TR=6NS CJE=2PF IS=6E-16
+ CJC=1PF VAF=100)
.MODEL QPL PNP(BF=40 RB=20 TF=.6NS TR=10NS CJE=1.5PF CJC=1PF VAF=50 IS=6E-16)
Thanks for the working .sub.
ericgibbs
Joined Jan 29, 2010
21,569
hi jii,
When you post an 'asc' file and a plot image, please make the asc file match the plot, so that we can compare exactly our results.
E
jjjjjjjjjx
Joined May 19, 2018
My bad. I didn't even realize I did so much modes and saves in a short time. I'll be more careful next time.
I played around the value for R26, it appears to be what's responsible of the output current cut off. A value of 0.0001 makes it drops off at 85A.
Alec_t
Joined Sep 17, 2013
15,156
Strange. When I run the post #1 asc file using the post #2 sub file I get this :
Edit: Ah, seems to be a pin order/name mismatch between the model and the symbol. Will have a play.
Edit 2: Sorted by editing symbol.
eetech00
Joined Jun 8, 2013
4,724
hi
I didn't try your model because it wasn't shared...but mine works ok.
Try lowering the set resistor (R1) to 240 and recalculate R2. I believe there needs to be at least 5ma flowing thu the set resistor for it to regulate properly.
