LM317 Issue??
Dr.killjoy
Joined Apr 28, 2013
1,196
I was bread boarding a simply lm317 circuit to drop 24vdc to 18vdc but I have some problems ..I am trying to charge a JumpBox or Jump Pack( It's what you use to jump your car when the batteries dead )... The original charger was a wall wart that was 120vac to 18vdc 500ma and it took a crap ..But I found a 120vac to 24vdc wall wart and I hook up my lm317 circuit in order to the 24vdc to 18vdc .. The problem came when I was measuring the output voltage ..When I breadboard it ,I used my power supply set to 24vdc -400ma and the output set to 18vdc with a small load ..I hook up the output to charging port of the jump box and the voltage suddenly jumped down and the power supply output voltage dropped too but I tried to increase the voltage but nothing changed but I could increased the current but not would change ..I am using ebay bought lm317 and I am not sure if they where the problem ..
Specs
R1-240ohm
R2-3.3Kohm
Power supply
Mastech D3003
Max 30vdc\3amps
Thanks
Jay Sr
#12
1) The 317 needs 10 ma of load. The first resistor is usually 120 ohms, not 240. If you have a permanent load, that will not be necessary.
2) Which 317? The TO-92 package only passes 100 ma.
3) If your jump battery is really awfully bad, even a TO-220 will go into safety lock-out.
30V - 12V is 18 watts per amp. Overheat threat will force the 317 into safety lock-out.
4) Did you add the little capacitors in the datasheet? They really are important to keep it from oscillating.
Dr.killjoy
Joined Apr 28, 2013
1,196
The data sheet suggest using the 240 and I am using a through hole T0-220 and I follow the datasheet to the T with caps before and after the lm317..
I am not sure what I did wrong here but my though is the jump box is sink to much current and causing the voltage drop ?? The jump box has a charging circuit inside
and I am not sure if the circuit is broken or if I am doing something wrong ?
http://www.ti.com/lit/ds/symlink/lm317.pdf
Wendy
Joined Mar 24, 2008
23,801
The circuit I published works, and 120Ω is usually the required value.
It guarantees the required 10ma though the LM317 to power it up.
38,650
Doesn't this Jump Pack contain a 12V lead acid battery?
What voltage did your new charger go to when you connected it?
A 12V lead-acid battery needs about 14V to charge it. I suspect the original charger had internal resistance that dropped the voltage when it was charging.
Brownout
Joined Jan 10, 2012
2,390
Your power supply is current limiting. I doubt the 317 has anything to do with that. What do you expect the charge current to be? Are you sure you're current limit is high enough? BTW, you won't see any change while adjusting the current limit until you set it high enough to turn current limiting off. This, the voltage will suddenly jump up to it's setting.
Dr.killjoy
Joined Apr 28, 2013
1,196
The box contains a sealed lead acid battery and I thing the voltage dropped to about 16vdc and I will have to change out the R1 resistor and see if that changes anything .. I also realized this is my last .1uf ceramic cap what the crap and I bought a couple packs of assorted ceramic packs from RS before they closed and between both packs I didn't get a single one ..I am about to head out and will post up my results later with pics and see if you guys see anything wrong ..
#12
It isn't possible to make a lead acid battery come up to 16 volts just because you set your regulator there. It will always load down to the battery voltage. You have to hit a battery that size with about a dozen amps to get the voltage that high, and it's still temporary. The battery will revert to its normal voltage as soon as you quit driving large amounts of current into it.
Dr.killjoy
Joined Apr 28, 2013
1,196
I set the power supply to 400ma of current and when the voltage dropped I increased the current to 3amps and still has the voltage dropped and won't come out of current mode at the 3 amps..
Dr.killjoy
Joined Apr 28, 2013
1,196
Have you tried just setting your power supply to 18v and connecting it directly?
Yeah but it sink all 3 amps at lower voltage .. I have a feeling I blew the charging circuit cause I opened the jump box case and it has a LM317 battery charger circuit and I think I wound up blowing up the circuit..I could be wrong but will post up pics up later of the circuit later ..
ian field
Joined Oct 27, 2012
6,536
Specs
R1-240ohm
R2-3.3Kohm
Power supply
Mastech D3003
Max 30vdc\3amps
Thanks
Jay Sr
Is your jump pack lithium? - If so, you might need to be a bit careful how you charge it!
If the precise voltage control for lithium is in the jump pack itself, you're probably OK - but if it relied on the wall wart for that, you could have a problem.
Brownout
Joined Jan 10, 2012
2,390
That tells you your circuit is not the problem.
