lm317 in series to get 2v, 2.5v and 3v using switches
hameed123
Joined May 21, 2018
8
HI, I would like to build voltage regulated source that should give 5 no's of 2v,2.5v and 3v .I am using(5 no's) lm317 with 3 resistance trimmer each connected with 3 turn switch.Idea is when turning switches i should get 2v,2.5,3v respectively.4 no's of lm317 isolated and 5th one is grounded.i got values for first 4 and not for 5/Pls help
ericgibbs
Joined Jan 29, 2010
21,650
hi 123,
Your diagram is so big I can see my house.;)
This clip showing only two sections of your diagram, which shows 5 identical circuits, is easier to follow.
E
hameed123
Joined May 21, 2018
8
YES ,,,,,4 LM317 ARE CONNECTED WITH NO GROUND AND THE 5 TH ONE IS GROUNDED...HEADER 3 IS THE 3 WAY TURN SWITCH TO GET 2,2.5,AND 3V RESPECTIVELY.......I NEED TO TAKE OUTPUT WHICH IS FROM HEADER 6(6 TH PIN IS GROUNDED TO 5 TH LM 317
I SHOULD GET 5 DIFFERENTIAL OUTPUT FROM HEADER PIN 6()
IF ALL THE SWITCH IS IN 1ST STATE THE OUTPUT SHOULD BE 2V
2 ND STATE -----2.5V
3 RD STATE -----3V
hameed123
Joined May 21, 2018
8
3 rd pin of header 3 will go to next lm317 positive terminal of cap 1uF
negative terminal of 1uF,0.1uF,10uF,and 27 ohms all interconnected to next lm 317 s positive terminal of 1uF
bertus
Joined Apr 5, 2008
23,037
I would check your connections.
Some spots are connected and some not ( I have circled them).
Also the pots shouls have a connection to a reference ( I have drawn some ):
Bertus
dendad
Joined Feb 20, 2016
4,642
You must have at least one resistor to gnd, like R2 in the app circuit.
And try to keep the wires to the switches and pots as short as you can.
One problem with switched voltage setting is usually the output will go to the max it can as you switch from one setting to another as the switches go open.
Why do you want to use switches in stead of a pot?
And I see you are using a 10K resistor from output to adjust. Make it 240R or 220R and see if that helps. Then you can get rid of the 27R on each output.
