LM317 Calculator
chrissyp
Joined Aug 25, 2008
82
Hi All
I am new to the forum. i am a electronics troubleshooter for a uk company,specialising in power supplies and led lighting control.One of the regular transistors i use is the good old LM317. I have an EXCEL file to calculate R1 and R2.You can either key in the voltage you require and one of the resistor values or both resistor values and it will tell you the voltage you will get. The problem is either i am being thick of it's this b****y vista but it will not let me import it into a thread. If anybody can help me i will import it as i think there will be members that will find it useful.
SgtWookie
Joined Jul 17, 2007
22,230
It's because .xls is not an allowed format for file attachments.
You will need to use a file compression utility like WinZip or ZipGenius to create a .zip file, which you can then upload.
bertus
Joined Apr 5, 2008
22,999
For windows I use 7-zip for zipping stuf.
http://www.7-zip.org/
  • Supported formats:
    • Packing / unpacking: 7z, ZIP, GZIP, BZIP2 and TAR
    • Unpacking only: RAR, CAB, ISO, ARJ, LZH, CHM, MSI, WIM, Z, CPIO, RPM, DEB and NSIS
Greetings,
chrissyp
Joined Aug 25, 2008
82
Hi SGTwookie and bertus
Don't mis understand my response ,i am downloading a zip program and thank you for the help both now and back then when the question was first posted.
My earlier response was aimed at Raptor30 for his pointless and unhelpfull post.I appologise to sgt wookie and bertus if there was any mis understanding
scubasteve_911
Joined Dec 27, 2007
1,203
Honestly, it wasn't that pointless. The LM317 contains much circuitry (reference, opamp, pass transistor, etc) and shouldn't be confused with a transistor, as it often is, due to the typical TO-220 package.
Steve
SgtWookie
Joined Jul 17, 2007
22,230
You'll get slightly different values for R2 with my calculator than chrissyp's; that's because my version accounts for Iadj (current from the ADJ terminal) current flow through R2 where chrissyp's does not.
In most cases it makes just a very small difference, perhaps 4mV to 10mV per 1V of output, depending upon actual Iadj.
The LM317L requires a minimum of 5mA load to provide guaranteed regulation. Since Vref may vary as low as 1.2v and still be within specifications, in datasheets manufacturers may show a 240 Ohm resistor being used in some typical applications schematics. A 120 Ohm resistor is typically used for the standard versions of the LM317 if the load may occasionally be less than 10mA.
If you will always have a minimum of 10mA load on the output, you can use a much larger value for R1. However, this will make Iadj much more significant in the selection of R2.
Duxthe1
Joined Sep 27, 2008
9
Great post, I'm using the lm317 in a project but don't have Excel on my computer. Can someone calculate the values for me? I'm using a 5v supply and want a 3v output. I'm going to use a potentiometer for R2 so that I can trim the output +- a little. I have a 47k mini trim pot that would fit my board well but think it's value is way too high. Is it possible to use it with the right value for R1? If not what values are reccomended?
Apologies for the somewhat relevant hiack.
SgtWookie
Joined Jul 17, 2007
22,230
I wouldn't use your 47k pot. Even a 1k pot would be too large for this application, but a 1k 10-turn pot could be used.
If Vref=1.2, R1 should be 120 and R2 should be 178.9 Ohms.
If Vref=1.25, R1 should be 120 and R2 should be 167 Ohms.
If Vref=1.3, R1 should be 120 and R2 should be 156 Ohms.
AlexR
Joined Jan 16, 2008
732
Since we are exchanging spreadsheets here are my efforts at a ML317 calc (I think anyone who has ever used an LM317 has written a spreadsheet to work out the resistor values) and a rough and ready spread sheet for working out the minimum value of filter capacitor for any given rectified voltage and load.
Both spreadsheets were written in Open Office. The Excel versions have not been tested on Excel software but in theory should work ok.
