LM2576T Adjustable trimmer circuit check.
jm-a
Joined Oct 20, 2010
111
Hi all,
I've just drawn a simple circuit with LM2576t Adjustable Switcher.
I'd want to get a versatile psu, 3A , from 1.3 to 15 V.
I'm in doubt about proper wiring of trimmer - see pink ovals - bourns 50 K 24 turns.
Could you check the entire board also, in order to avoid wasting money ....... ?
As usual, thanks a lot.
Jm
Sensacell
Joined Jun 19, 2012
3,784
Fix your grounds on the PCB.
Make ground planes as much as possible. Consult the LM2576 data sheet for layout tips.
Remember - modern switching regulators are basically operating at RF frequencies, you need to use RF PCB design practices.
I have had NASTY troubles with boards that do not work due to poor layout.
jm-a
Joined Oct 20, 2010
111
jm-a
Joined Oct 20, 2010
111
Hi Sensacell,
First, thanks a lot for your reply.
My last pcb with same switchers, had some trouble too :(
Now, it works, don't know why???????????!!!!!! But after numerous trials, soldering, desoldering, and some pcb to trash, it's fine.
But ground plane aside, is trimmer and its traces correct?
Thanks a lot and nice day.
jm
