LM1085 vs LM2696, which is more reliable?
Glebiys
Joined Mar 11, 2019
23
I am designing a 12V / 5V 3A power supply. Having studied the solutions, I settled on two options from TI:
1) LM1085
2) LM2596
It seems that they are similar in characteristics, I did not find any special differences. Perhaps someone came across them and knows which is better?
As I understand it, LM1085 without a load can produce an input voltage at the output, which is not good.
The documentation also indicates the use of tantalum capacitors. I do not really like this idea because of the explosive nature of such elements. There is an idea to use polymer capacitors that are reliable and not very temperature sensitive. Is this a good plan?
atferrari
Joined Jan 6, 2004
5,032
1) LM1085
2) LM2596
The most espectacular explosion I recall was of an electrolytic. Celebrated loudly by all in the lab.
My tants had been all well behaved up to now.
Dodgydave
Joined Jun 22, 2012
11,395
LM2596 is a buck converter ic, better for low power wasting when drawing upto 3A, the Lm1085 is a Linear regulator like the Lm317.
