LM 2917N Tachometer
ahmedsaleh
Joined Feb 10, 2017
13
Where are you confused?
Max.
i need and simple explain because this circuit is my homework and i will be asked in it and the professor didnt explain any thing about it he just give us the schematic only and i want to know that is the function of this circuit ,etc
bertus
Joined Apr 5, 2008
22,995
@LesJones , The IRT is the IR transmitter, the IRR is the IR receiver.
I enhanced the picture a bit, so you can see the parts.
@ahmedsaleh ,Your drawing is hard to read.
I played a bit with brightness and contrast to have an other view on the picture.
Bertus
LesJones
Joined Jan 8, 2017
4,536
Hi Bertus,
I had missed the schematic in post #1. I was just looking at the picture from the data in post #2. I find it difficult to give clues for homework questions without giving the answer.
ahmedsaleh,
Starting from the left hand side. The infra red transmitter is just like a normal LED but the wavelength of the light is below the visible spectrum so you will not be able to see it.. So if it was a normal LED what do think the effect of adjusting the variable resistor in series with it would be ?
(Correction I should have said the wavelength of infra red is above the visible spectrum. It is UV that is below.)
Les.
ahmedsaleh
Joined Feb 10, 2017
13
Hi Bertus,
ahmedsaleh,
Les.
That's my question i dont know the function of the irr and irt and pots ?
Alec_t
Joined Sep 17, 2013
15,152
Re-read posts #7 and #8.
"Pot" = potentiometer. This can be used as a potential divider (all three terminals in use) or simply as a variable resistor (only two terminals essential in use, but the centre terminal is usually shorted to an end terminal).
LesJones
Joined Jan 8, 2017
4,536
Hi Alec,
I think Max's comments in post #8 were aimed at me. I had missed the scematic in post #1 so I was trying make sense of the comments in post #5 thinking they were related to the schematic post #2. (It was my mistake.)
Les.
