If the starter is a problem you could connect a transistor to remove power to the gauges when the starter is engaged.
For LTspice files, the .sub or .lib file goes in the LTspice sub folder.
The .asy file goes in the appropriate LTspice sym folder (for the LM339 that would be the Comparator folder).
