Lithium ion cells failure mode from overvoltage...
Externet
Joined Nov 29, 2005
2,636
Hi.
The charge regulation voltage failed and applied about 5 Volts to several 16850 paralleled cells. All kaput. Did it create an irreversible chemical reaction with not a chance of recovery, right ?
pwdixon
Joined Oct 11, 2012
488
Probably lucky you didn't have a fire.
Not sure it's worth thinking "can I fix these" as they might now be unreliable in some way and future fire risk could be a concern.
I've never had a fire with a battery but then I've never abused one, I do know there's always been a general suggestion that charging problems can cause problems.
Hypatia's Protege
Joined Mar 1, 2015
3,228
If the Li-ion batteries are incorporated in a 'pack' their apparent failure may owe to an open thermal 'fuse' -- otherwise they're probably "beyond the vale" --- I concur with Post #2 as regards safety/reliability concerns attendant to 'resurrected' cells...
Best regards
HP
PS -- Why on earth do you wish to abolish the decibel???:confused:
kubeek
Joined Sep 20, 2005
5,796
That depends if the cells have internal protection circuitry or not. But either way they are probably toast.
