I have three inter-connected smoke detectors. One of them repeatedly loses electrical contact with the AC. After having cleaned the contacts and the plug that connects the detector to Hot, Neutral and Alarm, the detector works for a while. It's battery backed up, so there's no need to go into concerns about that. The unit that keeps failing is near the swamp cooler (evaporative cooler), which, as you probably know, is an outflow of humid cold air. The humidity (I'm guessing) is causing oxidation or corrosion between the pins and the connectors. The other two have had no such failures. When I swap them the non-functioning unit functions in the second or third location. So I'm fairly confident the main issue is the cooler. I'd like to put some sort of electrical coating on them that would prevent moisture from reaching the contacts while at the same time not creating a pathway for electrons to short out from Hot to Neutral (or to the 10VDC alarm line).
THE QUESTION:
Will white lithium grease safely insulate the pins without causing electrical issues?
THE QUESTION:
