Hi guy's I could use a little assistance to work out some 12 vdc wiring. I have a 12.5 kw generator totally enclosed with a damper to let air in for cooling I have instal an actuator to open or close the damper, from my genset controller I have digitals inputs and outputs what I wish to do is on start of the genset is to use a momentary pulse to fully extend an actuator (with built in limit switch) and when turning of the genset will retract the actuator using the same input to drive the relay so to inverse polarity. Many thanks in advance..
