linear actuator
andyjack38
Joined May 21, 2022
5
Hi guy's I could use a little assistance to work out some 12 vdc wiring. I have a 12.5 kw generator totally enclosed with a damper to let air in for cooling I have instal an actuator to open or close the damper, from my genset controller I have digitals inputs and outputs what I wish to do is on start of the genset is to use a momentary pulse to fully extend an actuator (with built in limit switch) and when turning of the genset will retract the actuator using the same input to drive the relay so to inverse polarity. Many thanks in advance..
MaxHeadRoom
Joined Jul 18, 2013
30,658
So you wish to use the same signal to initiate the actuator return signal as the forward stroke ?
What is the nature of the momentary signal?
andyjack38
Joined May 21, 2022
5
Hi, the only thing that I have is a picture of the relay, I taught it would have been a wiring schematic, a nice picture in fusion 360
vu2nan
Joined Sep 11, 2014
357
Hi Andy,
A DPDT 'Ratchet Relay' may be used to reverse the polarity of the voltage, applied to the linear actuator motor, to open / close the damper.
Limit switches, built into the actuator, stop it's actuation at the end of travel in either direction.
The voltage gets reversed with every consecutive pulse to the ratchet relay coil.
The voltage and pulse width are to conform to the manufacturer's specifications.
Nandu.
MaxHeadRoom
Joined Jul 18, 2013
30,658
If you use that circuit, you should not need the diodes and limit switches as they are most likely already in the actuator.
Do you know the duration of the pulse?
The Ratchet relay actuates on-off-on on every pulse
