MisterBill2
- Joined Jan 23, 2018
- 28,272
A 20 volt motor running on 19 volts and less than maximum load should work well enough.
OK thank you!A 20 volt motor running on 19 volts and less than maximum load should work well enough.
Given the old motor ran off batteries, probably AA cells which are pretty poor at high current loads, my view is you are over thinking the problem.
Put the motor in the clipper and try it. If it's truly a more powerful motor, chances are it will work ok. A bigger problem might be if it's revs are much higher so cutting torque might be actually lower despite being more powerful. Try it and see.
I will...thank you!Given the old motor ran off batteries, probably AA cells which are pretty poor at high current loads, my view is you are over thinking the problem.
