Limiting current, without dropping voltage.
maxdha
Joined Dec 3, 2023
27
Hi! I have a circuit that is supposed to supply 10mA maximum. I don't want it to supply more, even if it needs to.
How can I do that without dropping any voltage?
I don't want to use any microcontrollers.
dl324
Joined Mar 30, 2015
18,469
You need to provide more information. What is the supply voltage? What is the load? What voltage does the load require?
You always need to drop voltage somewhere for the current sense resistor.
You're in luck. Microcontrollers aren't usually used for current limiting.
maxdha
Joined Dec 3, 2023
27
I supply 12V DC. The load requires 12V, but it can go down to 11V.
35,187
Not possible.
Let’s take an example.
Suppose the desired voltage is 10V.
If the current is limited to 10mA then the load has to be 1kΩ.
If the load drops below 1kΩ Ohm’s still rules.
I = V / R
The current has to go up or the voltage has to go down.
maxdha
Joined Dec 3, 2023
27
Not possible.
I = V / R
Ok is there an IC that drops the current, if it exceed a specific ampere? I would be ok with dropping the voltage..
35,187
It is called a constant current supply. You can design this with resistors, transistors, op amps, or voltage regulators.
dl324
Joined Mar 30, 2015
18,469
You could do something like this:
Change the supply to 12V, make R5 larger to limit the adjustment range of the pot. Make R1 some value (less than 50 ohms) that will drop less than a volt, but drop enough voltage for you to be able to set the current.
You can't use any opamp. LM358 is a very old design, but it was designed to allow the input voltage range to include ground and for the output to get very close to ground. You could use just about any opamp with rail-to-rail inputs, but that'd cost you around $1 and LM358 are cheap general purpose opamps.
At 10mA, MOSFET on resistance isn't too important, but lower is better. AO3400 is a logic level MOSFET (not important in this case) with an on resistance of about 0.04 ohms. It can handle 5A, also not important in this case.
If it wasn't obvious, you connect your load between power and the drain of the MOSFET.
maxdha
Joined Dec 3, 2023
27
Thank you :) That's what I needed.
dl324
Joined Mar 30, 2015
18,469
Thank you
You're welcome. If you post that circuit anywhere, be sure to give proper attribution.
If it's not obvious, you use R1 and R3 to set the current.
If you used 20 ohms for R1, you use Ohm's Law to calculate the voltage drop needed for 10mA. V = IR = 10mA*20 ohms = 0.2V, so you'd set the pot for 0.2V. With the R5 value in the schematic, the adjustment range is 0-0.8V. Making R5 larger would give you finer control with R3.
R1 should be a precision resistor, at least 1%, depending on the current accuracy you need.
maxdha
Joined Dec 3, 2023
27
Thanks again. It would've taken me time to figure this out :D
You've been very helpful!
dl324
Joined Mar 30, 2015
18,469
You don't need to use a logic level MOSFET with that circuit. With a higher threshold voltage, you shouldn't have any problems using a 12V power supply because many MOSFETs have a 2-4V threshold voltage. That would require the opamp to apply a maximum of about 4V to the gate. The output of LM358 can only go as high as 2V below the supply voltage (10V in your case, so it should work with most MOSFETs - e.g. 2N7000 which is a low cost through hole part with a threshold voltage of 0.8-3V).
You could also substitute a BJT such as 2N3904. That makes the value of R4 a little more critical, but 100 ohms will still work. The base current shouldn't be large enough to be significant, but be aware that the current in the current sense resistor will be higher than the load (collector) current (because IE = IB + IC). In a worst case situation, there'd be about a 10% error.
EDIT: the resistor isn't actually required when using a BJT. It's there for MOSFETs to dampen potential oscillations from a capacitive load.
28,313
That is really quite simple. Just put a ten milliamp fuse in series with the circuit. No voltage drop problem until the fuse opens.
sparky 1
Joined Nov 3, 2018
1,218
The LM358 and some uncommon mosfet, The arrangement needs thermal compensation, mostly mosfet heat sinking ability.
LDO concideration is favorable with some mosfets. Typical LDO regulator voltage drops are 200mV or 300mV
Question of which common mosfet. Which garden variety mosfet that will do that is really available ?
The LM10 op amp came with a 200mV reference. Some have tryed TIP32.
Because circuit draws less than 10mA and the cost of an LM334 is still $0.39 vs cost of 1Watt 1% resistor limiter might be good enough.
Easier to just expect some voltage drop, also LM334 thermal compensation was addressed using diode.
The surplus market of past gave a limited availability of part types, now percentage imported are fake and noisy parts.
LM134/LM234/LM334 3-Terminal Adjustable Current Sources datasheet (Rev. E) (ti.com)
