Limited frequency
Antsy electron
Joined Dec 27, 2022
69
Ok , I finally made the below circuit to oscillates and even resonate. It resonates in a range from 18 to 21 mHz depending on me moving the inductor . However , no matter how many inductors I replace , how many capacitors I change it just doesn't oscillates or just does it in the same range above mentioned. How is this posible ?.
DickCappels
Joined Aug 21, 2008
10,661
MisterBill2
Joined Jan 23, 2018
28,130
For a stable mode of oscillation the circuit must have gain that exceeds the losses at the intended frequency. The circuit shown is indeed a poor design, and is not likely to ever work well.
The very first obvious flaw is that the tuned circuit is not directly tuned, which in this case insures instability. The circuit shown on the link is much better , but the link is obnoxious.
This circuit is in the class of what is often called "a blooper", meaning that in some constructed versions it may work, but the detailed explanation of exactly how it works is not clear.
Antsy electron
Joined Dec 27, 2022
69
T
[/QU
