Over voltage protection but the current has to be limited to uA.
ashokraj
Joined Feb 1, 2018
151
I am looking for a circuit which limits the voltage but it should have a leakage current less than 1mA.
My requirement is the following:
1. I am getting 5.6V from the boost circuit, I need to use a super cap at R6. I can use a zener to limit the voltage but it is having a very high leakage current. The zener diode i used has a zener voltage of 3.9V. If I go for very high zener voltage of 5.6 or 10V it will have low reverse bias current. but it will not meet my certification requirements. He applies a fault condition of Vz*1.05 which will damage the super cap.
Any insights on circuits of it should have a over voltage protection of 3.9V yet the current leakage should limit to less than 1mA?
I tried below circuit. in terms of voltage it is good but has a very high leakage current of 142mA.
Thanks,
Ashok
38,926
Below is the sim of a circuit using a TLV431 programmable shunt reference (Zener):
The TLV431 is a lower current and voltage version of the TL431.
The output voltage (green trace) is clamped to 3.9V for the R1-R2 resistor values shown.
The quiescent current should be less than 100μA below its regulating point.
28,517
Any shunt arrangement to limit voltage will certainly have a high leakage current. That is the truth. To limit the voltage for a load a series voltage regulator will avoid leakage current, but it will still not be as efficient as it should be.
That is all the advice I can give as we have not enough information..
neddie
Joined Sep 29, 2011
12
use a 5V6 zener in a series regulator , then drop the voltage to 3.9(ish) with 2 diodes.
This is just a sim , you would have to build the circuit in real life to test.
neddie
Joined Sep 29, 2011
12
or use the tlv431 as mentioned earlier , but in a series regulator configuration. This shows a normal tl431 , but I didn't have the model for the tlv. Same circuit. This is just the most basic circuit , in reality you may have to add some comp network on the ref pin of the tlv , but that won't affect the current.
38,926
That will have a least a 1V minimum voltage drop.
Don't know if that's acceptable for the TS's application.
If he use's a series regulator, then it likely should be one with a dropout voltage of near zero volts.
28,517
It might work to use a mosfet forced into saturation under normal conditions.
Now a question: Is the rated voltage to be held during an over-voltage incident? Or is a droput to some lower level, or zero, acceptable.
Do we even know what the over voltage-protected device is??
