lights for dolls house/ models
ancientone2023
Joined Jan 25, 2024
hi at moment trying to light a dolls house have an abundance of 3mm 2/3v 20ma warm white leds am thinking of using 20 or so was hoping to use batteries so far have about 8 in at moment wired in parallel using 2 aa batteries and very dim like me! think am missing something do i need more power or?
Jon Chandler
Joined Jun 12, 2008
1,619
Do you have current-limiting resistors for each LED? Are they pre-wired with resistors?
Pictures would be lhelpful along with a link to the LEDs.
ancientone2023
Joined Jan 25, 2024
sorry no link just chinese leds they are 3mm warm white polarity long lead (+) V(f) 3v - 3.2 1 (f) :20ma all i know sry. Dont have any resistors i think! just wired 8 up in parallel with 2 aa batteries and they are lit but dim.
Dodgydave
Joined Jun 22, 2012
11,395
From my experience with led lights for doll houses, they don't have any series resistors as they run on 3V batteries and rely on the internal resistance of the batteries. I rewired them with a 150 ohms resistor and run them on 5V phone charger they work perfectly fine.
tonyStewart
Joined May 8, 2012
238
I would use them wired as 4S powered by a 12V supply into a jack. Batteries won't last long. 5mm LEDs are more efficient and Vf ~ 3.1 and if ultrabright will be adequate and not have thermal runaway at lower Vf=12V
Audioguru again
Joined Oct 21, 2019
6,826
You said the ad for the LEDs say the max forward voltage is 3.2V. Then some of them will be dim when powered by 2 brand new AA alkaline batteries and even dimmer if the batteries are cheap (super-heavy-duty) or are old.
