MisterBill2
- Joined Jan 23, 2018
- 28,253
If it was really "BX" and not Greenfield, be very careful moving the wires when you work on the box. My experience with BX is that the steel sheath cut with whatever they used had a very sharp edge that cut thru the insulation and cause the breaker to trip. And there were none of those red collar pieces to protect the wire insulation.
The wires in "Greenfield" can move and be pulled out, while the wires in "BX" are not removable. And usually BX conductors have clothe covered rubber insulation.
