Hi all.
I'm currently prototyping a circuit that includes a "mini" solar charger for a 1 (or 2P) Li-On cell (18650 2600 mAh).
Right now the charger part is a slow charging circuit such that :
1. Begins charging when Vbat falls below 3.6 V
2. Applies a charging current from 0.05C to 0.1C (through a simple resistor whenever solar input allows).
3. Stops charging at exactly 4.1 V
The circuit includes temperature monitoring, undervoltage control (3.2 V limit), over-discharge current control etc.
This charging method was briefly mentioned somewhere (maybe at Battery University?), and I've been
testing it for some weeks with many new and not so new cells, with good results.
Of course it has some obvious drawbacks :
1. It's slow (in my case could not be otherwise due to solar cell power)
2. You lose some battery capacity (but not as much as one could think, compared with standard Li-On charging method, due to the small charging current, at 4.1 V the charge is higher than same voltage point in standard cycle.
So, considering this specific application, I would like to hear your comments mainly on :
1. Safety
2. Cell life
Thanks in advance.
1. Safety
2. Cell life
Thanks in advance.
