Li-ion powering a DC motor
gigabyte
Joined Aug 30, 2009
2
Hello, I'm new here. I was searching for a circuit to power a dc motor with a li-ion battery. I tested the dc motor with 3.7V DC form an ac-dc adaptor (3A) and it works...but when I try to connect the li-ion direct to the motor it don't starts and the voltage drops to 1.2V. I was thinking for using current limiter, MOSFET, or something else but didn't find out how to do it.
Can anybody help me please?
Thanks
PS: The DC motor is from this grass shears:
http://www.keengardener.co.uk/light...products/EdgingShear.jpg&width=230&height=220
pilko
Joined Dec 8, 2008
213
Check the battery.
-- Does it have suitable voltage and current rating?
--Is it fully charged?
pilko
oops crossed with gerty
R!f@@
Joined Apr 2, 2009
10,007
If the battery is not dead, then try recharging it with Li-on Charger first and then try.
a 3.7V li-on should be able to run ur motor for quite a while.
Even after charging the voltage drops below 3.7V at load then the battery is dying.
On the other hand if the cells AH capacity is rated at less than 1000mAh, then it won't last long or may even not start a 3A motor.
That motor will run best at 2Ah cells. Found in laptop battery packs. Try to get a laptop battery and rip it open. Inside you will find plenty of cells that would do your job. Does not matter if the battery is dead. Some cells inside will work fine once recharged using a 3.7V Li-on charger
gigabyte
Joined Aug 30, 2009
2
What kind of battery did you use? You'll have to give us more than
What voltage is the battery? Is it old and dead?
Sorry...the battery is brand new...charged...3.7V...and I thing it is size DD (cylinder)
The problem is that something in the grass shears burned and it didn't worked any more and the battery becomes dead....so I decidet to buy new battery and to do a simple circuit to power the motor. I didn't know what burned in the original circuit...it is SMD and is complicated circuit.
sceadwian
Joined Jun 1, 2009
499
It sounds like the battery monitoring circuit for your device has short circuited internally. DO NOT use lithium batteries in this device again until it has been replaced by a qualified person, you're lucky so far that you haven't had a fire.
Do NOT try to hack this device to work from a lithium battery yourself, again you'll either risk a fire or you'll simply go through batteries all the time.
Lithium batteries can not be discharged bellow approximately 2.7 volts or their lifespan will drop dramatically, if they're left in this state for any length of time they will become 'dead', there is nothing that can be done about this aside from having circuitry that will turn the device off before this occurs. This is what the SMD board in your device did.
Without knowing what you're doing continuing to play with your device is going to coast you time and money and leave you with a device that still isn't functioning.
marshallf3
Joined Jul 26, 2010
2,358
There are several writeups out there on "The care and feeding of LiIon batteries" and they are best aid attention to. Amid a lot of other variables they will last the longest if stored at only around an 80% charge and in the refrigerator.
Anyhow, now that we don't throw as many parties anymore since we've become serious the extra fridge in the garage is good for something again. :)
They have a limited life then they are usually internally disabled by some complex circuitry. Most monitor charged and discharged voltages along with charging rate curves but others actually just have a counter that keeps track of the number of charge/discharge cycles.
They are without a doubt the highest energy level per weight batteries on the market but the technology still has a ways to go.
sceadwian
Joined Jun 1, 2009
499
They also contain toxic metals, 4-7 times less energy by the same weight, and have a memory effect problem.
Although I do still wonder about the long term effects of the use of lithium in batteries... It's a very active metal, environmental impact in a throw away society is a little on the unknown side.
