I’m working on a piece of portable audio electronics and I’m running into some charging and power supply issues and would love some help figuring this out...
Project:
Problem:
I realized after designing the PCBs (and after doing some research) that the 2S board is only for battery management and needs a charging board and a constant current source in order to charge the cells safely.
Changes I’m making (tentatively):
What I’m trying to figure out:
The more I think about this/try to troubleshoot this, the more confused I get. Ultimately what I am trying to accomplish is to complete this circuit so it safely charges the cells with minimal (if any) PCB reworking, and a stable ~9V for the amp circuit and 5V for the signal board. Help would be greatly appreciated!
Project:
- Small 3-board build: power, signal (5 V), amp (needs ~9 V).
- Battery: 2 Li-ion cells (LP653042 3.7V 820mAh 3Wh) (https://www.amazon.com/dp/B08HJ53Q3C?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_5&th=1) with an 2S BMS board (https://www.amazon.com/dp/B07KSQY67X?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_5&th=1).
- Original power board parts: D1 = 1N4004 from DC jack to system bus, U1 = 7809 (9 V rail), U2 = 7805 (5 V rail).
Problem:
- Replaced D1 with a TP5100 module (to feed the 2S board) (https://www.amazon.com/dp/B0C78184C1?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1) module.
- Replaced U1 (7809) with an XL4015 module (https://www.amazon.com/dp/B0CYZH5VJ4?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1).
- Added a Schottky (1N5819) on the BMS from B− to P− (to help wake the FETs).
- On my PCB, the U1-OUT net is tied to P+ and due to the physical design of the PCB, it would be difficult to cut the traces to or from P+, so the output of the 7809 (or the XL4015 if used in its place) would have to simultaneously go to the S2 board, 7805, and power amplifier board.
- Given that U1-OUT = P+ on this PCB, what’s the safest, least invasive way to handle charging and the rails?
- Is there a clean approach that doesn’t require cutting traces?
- If a small mod (single trace cut or lifted pin) is the right answer, where would you do it?
- Any gotchas with using TP5100 vs XL4015 for a 2S charge path in this situation?
- Suggestions for current setpoint (cells are modest capacity) and blocking/backfeed considerations?
