Hello All,
I am currently working on a circuit that I want to input a small square waveform to.
The input signal characteristics are:
Square wave
f = 10kHz
Vpp = 2V
Voffset = 1V
Duty Cycle: 10%
I am using the non-inverting configuration with an op-amp. I have performed calculations to get a gain of 2V/V.
The circuit shown below is the topology that I am using. The Op-Amp in the diagram shows an AD op amp but I am using the LF356 op amp, this is just for illustration.
When connecting this circuit I get the following waveform
It looks like the output is saturating approximately at my +16V supply. I do not understand why this is happening nor do I understand how to fix this in a practical manner. I thought the op-amp would saturate at +/-8V input if I have a 2V/V gain and 16V supply.
I have found a fix for this but it involves adding some offset to the input voltage waveform which for some reason allows me to have more expected behavior at the output.
Any help on this issue would be appreciated.
Square wave
f = 10kHz
Vpp = 2V
Voffset = 1V
Duty Cycle: 10%
